[OpenLayers-Users] CVS format for OpenLayers.Layer.Text?
Erik Uzureau
euzuro at gmail.com
Wed Jan 31 17:10:06 EST 2007
Salut Alexandre,
Thanks for bringing this to the forefront. There is still a ton of work to do
on OL to get it up to a reasonable state in terms of documentation. The first
step is getting the new JSDOC working[1][2].
If we can find a volunteer to take these on, that would be awesome, but
if not we'll just have to wait it out a bit until some schedules clear up. :-)
Erik
[1] http://trac.openlayers.org/ticket/418
[2] http://trac.openlayers.org/ticket/419
On 1/31/07, Alexandre Leroux <alexandre.leroux at ec.gc.ca> wrote:
> Thanks Bill,
> It now works wonderfully :-) The documentation really needs updates!
> It's also indicated in the doc that OpenOffice can generate the "CVS"
> file for OpenLayers.Layer.Text while it can't generate the required
> tab-delimited file.
> Cheers,
> Alex :-)
> Bill Woodall wrote:
> > On Wed, 2007-01-31 at 20:06 +0000, Alexandre Leroux wrote:
> >> Hi list,
> >> Wow. OpenLayers is so easy to use. I'm enthusiastic :-)
> >> Using 2.3-rc2, I have some problems with:
> >> http://openlayers.org/doc/reference.html#OpenLayers.Layer.Text
> >> It is said the textfile must be in CSV, but when looking at the example
> >> textfile.txt, here copied:
> >> point title description icon
> >> 10,20 my orange title my orange description
> >> 2,4 my aqua title my aqua description
> >> 42,-71 my purple title my purple description<br/>is great.
> >> http://www.openlayers.org/api/img/zoom-world-mini.png
> >> This is obviously not comma separated.
> >> I failed to generate any text file that would be successfully read by
> >> OpenLayers.Layer.Text. Anyone can reduce the confusion?
> >> Thanks,
> >> Alex
> > Hi Alex,
> > The docs should refer to the textfile as a Delimiter-separated values
> > (DSV) instead of Comma-separated values (CSV) and in this case the DSV
> > are tabs.
> > The required columns for the textfile are;
> > point x,y pair in the appropriate units
> > or
> > lon the "x" coordinate
> > lat the "y" coordinate
> > optional columns are;
> > title popupContentHTML Title
> > image,icon url to the "stick pin" image/icon
> > iconSize yes, the size you want the image/icon to be
> > iconOffset you guess it, the offset
> > (for a stickpin use something width/2,-height to position
> > the image/icon over the point )
> > description popupContentHTML desc
> > Hope that helps
> > .........Bill,
> > OL/TC user
> Alexandre Leroux, M.Sc., Ing.
> Environnement Canada / Environment Canada
> Centre météorologique canadien / Canadian Meteorological Centre
> Division de la réponse aux urgences environnementales /
> Environmental Emergency Response Division
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
