[OpenLayers-Users] Problem using EditingToolbar Control with EPSG:23030
Ruben Pardo correosig at gmail.com
Mon Jul 2 13:39:33 EDT 2007
i trying to put a EditingTool Control in my map. My problem is that the
editing toolbar doesn't work correctly.
I need to use a projection EPSG:23030 on the layers that i show,
because of that, i need to put on the vector layer the projection, a
maxExtent and a resolution, in other cases
it doesn't paint anything.
In the cases that paint something, the behaviour is:
1) It paints the features but only when i press double click (at the time i
am drawing it doesn't paint anything), in big scales.
2) In small scale the behaviour is different, it shows me the features at
the same time i am drawing but when i do a double click
what i am doing wrong?
thanks very much.
The code is:
<html xmlns="http://www.w3.org/1999/xhtml">
  <head>
    <style type="text/css">
        #map {
            width: 800px;
            height: 475px;
            border: 1px solid black;
    </style>
    <script src="../lib/OpenLayers.js"></script>
    <script src="../lib/Firebug/debug.js"></script>
 <script type="text/javascript">
        var lon = 5;
        var lat = 40;
        var zoom = 5;
        var map, layer;
        function init(){
            map = new OpenLayers.Map( 'map', { controls: [] } );
        layer = new OpenLayers.Layer.WMS( "PARCELA","
http://192.168.212.20:84/cgi-bin/mapserv.exe?",{layers: 'PARCELASDE'},
            {projection:"EPSG:23030",maxExtent:new OpenLayers.Bounds(
182295.49,4135348.22,225743.19,4171432.55),maxResolution:'100'} );
  vlayer = new OpenLayers.Layer.Vector(
"Editable",{projection:"EPSG:23030",maxExtent:new OpenLayers.Bounds(
    map.addLayer(vlayer);
    map.addLayer(layer);
            map.addControl(new OpenLayers.Control.PanZoomBar());
            map.addControl(new OpenLayers.Control.EditingToolbar(vlayer));
 //if (!map.getCenter())
                      map.zoomToMaxExtent();
    </script>
  </head>
  <body onload="init()">
    <div id="panel"></div>
    <div id="map"></div>
  </body>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070702/468953af/attachment.html
