[OpenLayers-Users] strange click events with internet explorer
Erik Uzureau erik.uzureau at metacarta.com
Mon Jul 9 12:37:49 EDT 2007
...so the functionality that you want here is to be able to override
the cached offsets in getMousePosition?
Maybe we should make that an option (for people whose pages are doing
funky things)?
I know that the offsets are in there because those mousing functions
get called a *lot* and the less overhead in them the better.
Thoughts? anyone?
Erik
On 6/1/07, Christian Sengstock <csengstock at gmail.com> wrote:
> After debugging i found the problem to be in the method:
> OpenLayers.Events#getMousePosition
> Problem is, that i have my map div element in a "dislpay:none" div at
> startup (so the map div offsets are 0). However inside of
> #getMousePosition there's just once the check for the div offsets at
> first method call. After that the offsets are saved as a member var.
> So my problem was solved by checking the map div element offsets each
> time i call #getMousePosition .. thus:
> getMousePosition: function (evt) {
>        // if (!this.element.offsets) {   // COMMENTED
>             this.element.offsets = OpenLayers.Util.pagePosition(this.element);
>             this.element.offsets[0] += (document.documentElement.scrollLeft
>                          || document.body.scrollLeft);
>             this.element.offsets[1] += (document.documentElement.scrollTop
>                          || document.body.scrollTop);
>        // } // COMMENTED
>         return new OpenLayers.Pixel(
>             (evt.clientX + (document.documentElement.scrollLeft
>                          || document.body.scrollLeft)) -
> this.element.offsets[0],
>             (evt.clientY + (document.documentElement.scrollTop
>                          || document.body.scrollTop)) - this.element.offsets[1]
> I saw that most of the click handling stuff comes from the prototype
> library. Wouldn't it be easier using the prototype methods directly (
> and make use of all the benefits of a constantly enhanced library) ?
> Chris
> 2007/5/31, percy <percyd at pdx.edu>:
> > This sounds similar to a problem I had last October. I think it was
> > fixed in version 2.2, I'll paste the email below...
> > Percy
> > -------- Original Message --------
> > Subject: Re: [OpenLayers-Users] "interesting" cross browser problem
> > with    mouse click position
> > Date: Fri, 27 Oct 2006 11:09:34 -0700
> > From: percy <percyd at pdx.edu>
> > To: Christopher Schmidt <crschmidt at metacarta.com>
> > CC: users at openlayers.org
> > References: <20061011160003.A6010EDFAF at rainier.metacarta.com>
> > <45401072.3020304 at pdx.edu>      <20061026143712.GB15808 at metacarta.com>
> > that fixed it, thanks!
> > any idea when 2.2 will become the "stable" release?
> > I just got the SVN version out yesterday and was playing with that SWEET
> > new MousePosition control. I need to wait to put that on our production
> > server until it gets blessed, though.
> > Thanks again for the groovy interface,
> > Percy
> > Christopher Schmidt wrote:
> >  > On Wed, Oct 25, 2006 at 06:33:38PM -0700, percy wrote:
> >  >> Hi All,
> >  >> We are attempting to use an openlayers frontend to a kamap tiled
> > backend.
> >  >> My test page, http://ngmdb.usgs.gov/ol/examples/ngmdb4.html , works
> >  >> great in both "major" browsers. However when we integrate it into the
> >  >> main search page (which is not yet on a public site, but here's a
> >  >> simpler Kamap version: http://ngmdb.usgs.gov/ngm_compsearch_map.html) we
> >  >> get errant behaviour with regard to how the mouseclicks are handled by
> >  >> OpenLayers in FireFox!
> >  >> to see this in action, just edit your test file by sticking in this div
> >  >> just after the body tag:
> >  >> <div style="width:600px;height:800px;background-color:#008800;">
> >  >> Push the map down the screen
> >  >> </div>
> >  >> and then load the test file in a browser. firefox will exhibit the same
> >  >> breaking behavior as it does on the working page!"
> >  > Mistakenly sent my response to Percy, rather than to the list: This was
> >  > fixed with r1692, http://trac.openlayers.org/changeset/1692 closing bug
> >  > #333, http://trac.openlayers.org/ticket/333 , and the patch available at
> >  > the bottom of the page on r1692 should allow you to fix this issue for
> >  > older OpenLayers instances. Alternatively, this fix is included in the
> >  > 2.2-rc1 currently being tested, and will be included in the final 2.2
> >  > release.
> >  > Regards,
> > > On Thu, May 31, 2007 at 11:00:08AM +0200, Christian Sengstock wrote:
> > >> Is this a known problem and is there maybe a workaround? I think the
> > >> problem depends on where the map div is located in the DOM, because it
> > >> worked properly when i tested the MouseToolbar with a very basic html
> > >> page (just the map div).
> > > I'm not aware of this problem, or a workaround. (This just means I
> > > haven't run into it, largely because I mostly use simple DOMs :))
> > > Anyone else run into this issue?
> > > Regards,
> > David Percy
> > Geospatial Data Manager
> > Geology Department
> > Portland State University
> > http://gisgeek.pdx.edu
> > 503-725-3373
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
