[OpenLayers-Users] ctrl-z behaviour while editing linestring
Richard Duivenvoorde
rdmailings at duif.net
Wed Jul 11 11:16:12 EDT 2007
Hi Jachym,
My problem is a little easier then yours I think. I know for sure there
is always just one linestring in my drawinglayer/handler.
The clue from your code was that the handler has the current geometry
you are drawing, couldn't find that myself :-o
I'm not a javascript guru either, but my (probably not so faulttolerant)
little hack now is:
var feature = myLineControl.handler.line;
if(feature.geometry.components.length >1){
var lineidx = feature.geometry.components.length-1;
feature.geometry.removeComponent(
feature.geometry.components[lineidx]);
lineControl.handler.modifyFeature();
lineControl.handler.drawFeature();
It's maybe more clean to do it your way: make a new control.
Thanks for your help!
Jachym Cepicky wrote:
> Hi,
> I have this - using [backspace] or [delete] buttons, which is IMHO more
> intuitive for normal users, than ctrl+anything
> here part of the code:
> map.addControl(new OpenLayers.Control.KeyboardActions());
> OpenLayers.Control.KeyboardActions = OpenLayers.Class.create();
> OpenLayers.Control.KeyboardActions.prototype =
> OpenLayers.Class.inherit( OpenLayers.Control, {
> * @constructor
> initialize: function() {
> OpenLayers.Control.prototype.initialize.apply(this, arguments);
> destroy: function() {
> if (this.handler) {
> this.handler.destroy();
> this.handler = null;
> OpenLayers.Control.prototype.destroy.apply(this, arguments);
> draw: function() {
> this.handler = new OpenLayers.Handler.Keyboard( this, {
> "keypress": this.defaultKeyPress });
> this.activate();
> * @param {Integer} code
> defaultKeyPress: function (code) {
> switch(code) {
> case OpenLayers.Event.KEY_BACKSPACE:
> this.onBackspace();
> break;
> case OpenLayers.Event.KEY_DELETE:
> this.onBackspace();
> break;
> case OpenLayers.Event.KEY_ESC:
> this.onEsc();
> break;
> onBackspace: function () {
> // are we digitizing something?
> if (BNInfoButtons.polygonQuery.active) {
> var feature = BNInfoButtons.polygonQuery.handler.polygon;
> var polyidx = feature.geometry.components.length-1;
> var pointidx =
> feature.geometry.components[polyidx].components.length-2;
> var point =
> feature.geometry.components[polyidx].components[pointidx];
> BNInfoButtons.polygonQuery.handler.line.geometry.removeComponent(point);
> BNInfoButtons.polygonQuery.handler.polygon.geometry.removeComponent(point);
> BNInfoButtons.polygonQuery.handler.drawFeature();
> onEsc: function () {
> BNQueryPanel.activateControl(BNInfoButtons.navigation);
> BNQueryPanel.activateControl(BNInfoButtons.polygonQuery);
> /** @final @type String */
> CLASS_NAME: "OpenLayers.Control.KeyboardActions"
> Since I'm not a JavaScript coder (I'm actually no coder at all), I will
> be thankful for any comments.
> Jachym
> Richard Duivenvoorde píše v Út 10. 07. 2007 v 19:01 +0200:
>> Hi all,
>> while the editing of a feature is not yet available in 2.4 (by the way:
>> any roadmap available for editing an excisting feature?), I thought it
>> would be nice to have some 'undo' functionality. So while somebody is
>> drawing a (sometimes rather large) linestring and does ctrl-Z or
>> something like that, I want to grab the current linestring being edited,
>> remove the last added point and draw the (one point shorter) linestring
>> again.
>> I thought this would be easy, but it isn't ( for me :-( ).
>> The Vector layer doesn't have the feature/geometry in it's hands while
>> you are drawing it, and the point-callback get's a 'Point' as argument
>> (instead of the Linestring?).
>> Have been looking into the source of the DrawFeature control and Path
>> Handler, but couldn't find a hook.
>> Somebody an idea for implementing this?
>> TIA
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
