[OpenLayers-Users] Problem with zoomexents and google maps layer
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jul 16 10:43:13 EDT 2007
Chris,
Attached is an html test case. You will probably need to set the google
key to your host. This was run using OL 2.4. Sorry for the file instead
of a URL, I didn't have a host with a google key that was publically
accessible and readily accessible to me to post the example.
Les also tried John Cole's suggestion, but that did not solve the
problem either.
-Steve
Christopher Schmidt wrote:
> On Fri, Jul 13, 2007 at 05:43:42PM -0400, Stephen Woodbridge wrote:
>> Hi all,
>> I have run into an annoying issue that if you zoom to an extents the
>> extents is not always inside the viewport, so if I have a bunch of
>> points and zoom to their extents, sometimes some of the points are
>> outside the viewport after the zoom.
>> Is there a fix or workaround for this problem?
> Can you provide a test case for this?
> Regards,
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070716/f7537efc/google-ol-bug.html
