[OpenLayers-Users] Hard to click on points for GetFeatureInfo
Dmitri Mizerkin
eisberg at gmail.com
Fri Jul 20 02:33:06 EDT 2007
Hi Bill,
that's the right way to do it. What I meant is setting the tolerance via
URL, in your case it would be sth like
http://youhost/...&map_layer_0_tolerance=1&map_layer_0_toleranceunits=feet(I
don't know if the underscores in your layer name won't affect the
functionality so I'm assuming that it is the first layer in the mapfile and
using the index of it). More information can be found on
http://mapserver.gis.umn.edu/docs/reference/cgi/controls in the very last
chapter "Changing map file parameters via a form or a URL".
Hopefully it helps Marc with his issue.
Regards,
Dmitri
2007/7/20, Bill Woodall <bwoodall at bwoodall.org>:
> Hi All
> What has worked for me in using TOLERANCE is to put it into the mapfile
> ( if you are using MapServer) like ;
> LAYER
> NAME Scrub_and_Chaparral
> TEMPLATE blank
> TOLERANCE 1
> TOLERANCEUNITS feet
> METADATA
> "wms_title" "Scrub_and_Chaparral"
> "wms_include_items" "CATEGORY,LEGEND,SOURCE"
> END
> TYPE POLYGON
> STATUS ON
> DATA Scrub_and_Chaparral
> ......Bill,
> On Thu, 2007-07-19 at 20:08 +0200, Dmitri Mizerkin wrote:
> > Hi Marc,
> > in a WMS/WFS service request the attribute you are looking for is
> > called TOLERANCE. I think this should do it when set as a parameter in
> > getFullRequestString function (see user recipies:
> > http://trac.openlayers.org/wiki/GetFeatureInfo).
> > Hopefully it helps you out.
> > Cheers,
> > Dmitri
> > 2007/7/19, Marc Desharnais <marc.desharnais at ec.gc.ca>:
> > Hi all,
> > I search for an attribute to set to make it easier to click on
> > points to
> > get some info about them.
> > I tried some things like RADIUS or REDIUS (saw that on a page
> > on
> > internet) but nothing works.
> > I just want it to be easier to click on the point if it's
> > possible, a
> > couple of pixels more.
> > Thank in advance,
> > Marc
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> > Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070720/e1ddfaae/attachment.html
