On Fri, Jul 20, 2007 at 01:50:21AM -0700, Simo D wrote: > > Hi, > I found wich is the problem. > The parser can't parse the <geo:Point> tags. > If I remove theese tags from the code it works fine. Thanks. We'll put that into the bug report. Regards, -- Christopher Schmidt MetaCarta
