[OpenLayers-Users] Hard to click on points for GetFeatureInfo
Dmitri Mizerkin
eisberg at gmail.com
Fri Jul 20 08:58:37 EDT 2007
Mi Marc,
so you have to request feature from the server, not feature info.
A click event on a map returns the values for x and y in the view port. You
should make a box of those adding and substracting a custom tolerance value.
After you've done so you got 4 values: minx = x - tolerance, miny = y -
tolerance, maxx = x + tolerance, maxy = y + tolerance. These can be
converted to latitude-longitude values using OpenLayers (
map.getLonLatFromViewPortPx function). After all of these actions you get
your BBOX so you can send a request to the geoserver like this:
http://your_host/geoserver/wfs?REQUEST=GetFeature&SERVICE=WFS&VERSION=1.0.0&TYPENAME=your_layer_names&BBOX=your_bbox&MAXFEATURES=10
That's the only workaround I know.
Cheers,
Dmitri
2007/7/20, Marc Desharnais <marc.desharnais at ec.gc.ca>:
> Hi all,
> I'm using geoserver so I guess your solution won't work. Anyone has an
> idea about setting a tolerance level in geoserver?
> Or anything that would make it easier to click on a point of a map with
> geoserver.
> Thanks,
> Marc
> Dmitri Mizerkin wrote:
> > Hi Bill,
> > that's the right way to do it. What I meant is setting the tolerance
> > via URL, in your case it would be sth like
> http://youhost/...&map_layer_0_tolerance=1&map_layer_0_toleranceunits=feet
> > (I don't know if the underscores in your layer name won't affect the
> > functionality so I'm assuming that it is the first layer in the
> > mapfile and using the index of it). More information can be found on
> > http://mapserver.gis.umn.edu/docs/reference/cgi/controls in the very
> > last chapter "Changing map file parameters via a form or a URL ".
> > Hopefully it helps Marc with his issue.
> > Regards,
> > Dmitri
> > 2007/7/20, Bill Woodall <bwoodall at bwoodall.org
> > <mailto:bwoodall at bwoodall.org>>:
> > Hi All
> > What has worked for me in using TOLERANCE is to put it into the
> > mapfile
> > ( if you are using MapServer) like ;
> > LAYER
> > NAME Scrub_and_Chaparral
> > TEMPLATE blank
> > TOLERANCE 1
> > TOLERANCEUNITS feet
> > METADATA
> > "wms_title" "Scrub_and_Chaparral"
> > "wms_include_items" "CATEGORY,LEGEND,SOURCE"
> > END
> > TYPE POLYGON
> > STATUS ON
> > DATA Scrub_and_Chaparral
> > ......Bill,
> > On Thu, 2007-07-19 at 20:08 +0200, Dmitri Mizerkin wrote:
> > > Hi Marc,
> > > in a WMS/WFS service request the attribute you are looking for is
> > > called TOLERANCE. I think this should do it when set as a
> > parameter in
> > > getFullRequestString function (see user recipies:
> > > http://trac.openlayers.org/wiki/GetFeatureInfo).
> > > Hopefully it helps you out.
> > > Cheers,
> > > Dmitri
> > > 2007/7/19, Marc Desharnais < marc.desharnais at ec.gc.ca
> > <mailto:marc.desharnais at ec.gc.ca>>:
> > > Hi all,
> > > I search for an attribute to set to make it easier to
> > click on
> > > points to
> > > get some info about them.
> > > I tried some things like RADIUS or REDIUS (saw that on a
> > page
> > > on
> > > internet) but nothing works.
> > > I just want it to be easier to click on the point if it's
> > > possible, a
> > > couple of pixels more.
> > > Thank in advance,
> > > Marc
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org <mailto:Users at openlayers.org>
> > > http://openlayers.org/mailman/listinfo/users
> > > Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070720/3abf4a1a/attachment.html
