[OpenLayers-Users] OverviewMap in non wgs84 map
Tim Schaub tschaub at openplans.org
Wed Jul 25 12:41:22 EDT 2007
Hello-
Jachym Cepicky wrote:
> Hi,
> I would like to add OpenLayers.Control.OverviewMap() control to the map
> object, however, it works wrong. For example, one can take
> layer-opacity.html from the examples directory:
Please see the wiki page on the OverviewMap, specifically the section on
custom projections[1].
You'll want to construct your overview map with some non-default
options.  Set the mapOptions property of the options object as in the
example, and you should get what you want.
Tim
[1]
http://trac.openlayers.org/wiki/Control/OverviewMap#Customprojectionsextentsetc.
