[OpenLayers-Users] OverviewMap - bad coords?
Jeff Dege jdege at korterra.com
Wed Jul 25 15:18:56 EDT 2007
One more thing - looking at the properties for the tile image in the
overviewmap control that isn't being found, it has dimensions of
256x256.  Not the 200x200 I had specified.
So I set the tilesize in both OpenLayers and in KaMap to 256x256, and
now the OverviewMap seems to be working.
> -----Original Message-----
> From: users-bounces at openlayers.org
> [mailto:users-bounces at openlayers.org] On Behalf Of Jeff Dege
> Sent: Wednesday, July 25, 2007 2:08 PM
> To: users at openlayers.org
> Subject: Re: [OpenLayers-Users] OverviewMap - bad coords?
> On doing some websearching, I found changeset 3087, which
> looks like it
> might be a fix for the problem I'm seeing.  But it looks like 3087 was
> included in 2.4, and I'm still having the problem.
> I just DLed the trunk, and with that, I still have the problem.
> > Sent: Wednesday, July 25, 2007 1:51 PM
> > Subject: [OpenLayers-Users] OverviewMap - bad coords?
> > I'm trying to add the OverviewMap control to a map built with KaMap
> > layers.
> > I'm using OL version 2.4.
> > The example - examples\overviewmap.html - works perfectly.
> > Mine doesn't work at all.
> > When the OverviewMap control requests tiles from KaMap, the
> tiles are
> > generated correctly - or at least they seem to.  The
> > directory structure
> > looks fine, and the generated GIF files look fine.
> > But the tiles that are actually being requested don't
> > correspond to any
> > of the tiles that were generated.
> > The URL of the tile that was requested:
> > http://localhost:8080/servicearealookup/tile.php?map=mississip
> > pi&g=all&i
> > =gif&t=-768&l=-1536&s=19686393
> > Top is -768, left is -1536, scale is 19686393.
> > In the KaMap cache, there is a directory for scale 19686393,
> > and in that
> > a subdirectory for group "all", and for layer "def".
> > And in that, there is a subdirectory t-1200l-2400.  In
> that, there are
> > 36 GIF files, all of them blank except one, t-600l-1600.gif, which
> > contains the image that should be being drawn in the overview map at
> > this scale.  (Zoomed out all the way.)
> > Now I seem to remember having had a similar problem with
> KaMap on the
> > main map, because the default tile size in OpenLayers was
> > 256x256 and in
> > KaMap was 200x200.  Which I fixed by setting the tilesize
> > option to the
> > OpenLayers.Map constructor.  So I passed a tilesize option to the
> > OverviewMap constructor, and it made no difference.
> > Has anyone had any experience with the OverviewMap on KaMap layers?
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Users mailing list
