[OpenLayers-Users] ZoomToMaxExtent Control
Christopher Schmidt crschmidt at metacarta.com
Fri Jun 1 21:41:28 EDT 2007
On Fri, Jun 01, 2007 at 03:30:03PM -0600, Scott Davis wrote:
> Hey,
> Congrats on the 2.4 release.
> As I'm digging into the API, it appears that the ZoomToMaxExtent
> control is broken as shipped. (Please correct me if I'm wrong.) It
> seems to be missing the click handler and the associated CSS to get
> it to appear. I did the following to get it working. Am I on the
> right track?
The ZoomToMaxExtent control is actually designed to be added to a
Control.Panel object, as is demonstrated in:
http://openlayers.org/dev/examples/panel.html
In this case, the CSS, initialize, clicking behavior, etc. are all set
up by the Control.Panel.
I think this should solve any use case I can think of: if it doesn't,
I'd like to know about it. I assume that this is just a lack of
documentation. (For the record, you can remove the rest of the controls
from the panel and just get the zoomToMaxExtent control.
Does this help you?
Regards,
Christopher Schmidt
MetaCarta
