[OpenLayers-Users] updateSize on div resize
Kevin Kempfer mail at kevinkempfer.de
Sat Jun 9 11:15:58 EDT 2007
I dynamically change the size of the map div. Specifically, I try to add
a sidebar right next to it, making the map div a little less wide.
Calling map.updateSize() gives no error and the map looks fine, but the
OverviewMap is not moved to it's new position. As it is located in the
bottom right corner of the div, it should move to the left, when
decreasing the  map div's width. Is this by design? Is there a workaround?
Thanks,
Kevin.
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070609/0b31dc39/smime.bin
