[OpenLayers-Users] GeoRSS layer changes it name randomly
Erik Uzureau erik.uzureau at metacarta.com
Tue Jun 12 17:19:57 EDT 2007
Did this ever get filed as a ticket?
On 5/29/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, May 29, 2007 at 03:33:14PM -0600, Gregor Mosheh wrote:
> > Hiya. :)
> > I'm experiencing an odd behavior, which I suspect to be a bug.
> > This map has a GeoRSS layer and popup markers. In the layer controller
> > widget, the RSS layer's name will change spontaneously, which it
> > definitely should not be doing.
> It's not spontaneously: when the layerswitcher redraws (when you change
> a layer visibility, for example), it updates the name from a heuristic
> based on the URL to being the first 'title' element in the feed.
> > Should I file this as a bug, or is this supposed to happen?
> Yep, it should be filed as a bug.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070612/518b7999/attachment.html
