[OpenLayers-Users] Tiles removed too early
Erik Uzureau erik.uzureau at metacarta.com
Tue Jun 12 23:37:56 EDT 2007
Hola Kevin,
If you could send an example to the list, that generally helps for people to
understand the problem and help you debug it.
--Erik
On 5/31/07, Kevin Kempfer <mail at kevinkempfer.de> wrote:
> Hello,
> when I drag the map to the north, the tiles on the bottom edge of the
> screen are removed before they are outside the viewport. Dragging the
> map to the south is the same effect: The tiles are loaded too late. In
> both cases, there's whitespace visible.
> This only applies to north/south dragging, east/west is OK! The same
> happens when clicking on the navigation icons, so it should not be a
> problem with the mouse dragging feature.
> Is the a way to avoid this behaviour?
> Thanks,
> Kevin.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070612/b1218f4b/attachment.html
