[OpenLayers-Users] DrawFeature: how to clear?
Kevin Kempfer mail at kevinkempfer.de
Fri Jun 15 11:32:20 EDT 2007
Hello,
Christopher Schmidt schrieb:
>> how can I clear the map of all/specific drawed features?
>> example:
>> http://www.openlayers.org/dev/examples/draw-feature.html
> http://dev.openlayers.org/docs/OpenLayers/Layer/Vector.html#removeFeatures
Thanks. Works fine but I have a behaviour that is not clear to me. I can
reproduce it like this:
1. draw a feature (polygon, line, point)
2. select it (hover or click)
3. remove all features: vectors.removeFeatures(vectors.features);
- everything disappears as desired.
4. again, draw a feature
5. select it
What happens is the first (deleted) polygon re-appearing. Am I missing
something, here?
Here's the code:
var map, drawControls, vectors;
function createMap(){
  map = new OpenLayers.Map('map', {controls: []});
  var jpl = new OpenLayers.Layer.KaMap( "Satellite",
                     "http://dev/map.php", {g: "satellite", map:  "world"});
  jpl.displayOutsideMaxExtent = 1;
  vectors = new OpenLayers.Layer.Vector("Vector Layer");
  map.addLayers([jpl, vectors]);
  DrawControls = {
         point: new OpenLayers.Control.DrawFeature(vectors,
                    OpenLayers.Handler.Point),
         line: new OpenLayers.Control.DrawFeature(vectors,
                   OpenLayers.Handler.Path, options),
         polygon: new OpenLayers.Control.DrawFeature(vectors,
                      OpenLayers.Handler.Polygon, options),
         select: new OpenLayers.Control.SelectFeature(vectors),
         hover: new OpenLayers.Control.SelectFeature(vectors,
                                                   {hover: true})
  for(var key in drawControls) {
     map.addControl(drawControls[key]);
  var start_point = new OpenLayers.LonLat(8,50);
  map.setCenter(start_point,5);
         function toggleControl(element) {
             for(key in drawControls) {
                 var control = drawControls[key];
                 if(element.value == key && element.checked) {
                     control.activate();
                 } else {
                     control.deactivate();
         function clearall(){
         function clearSelected(){
         	vectors.removeFeatures(vectors.selectedFeatures);
Regards,
Kevin.
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070615/18b61d5c/smime.bin
