[OpenLayers-Users] Problem showing OpenLayer controls in a page with a DOCTYPE
Ruben Pardo correosig at gmail.com
Thu Jun 28 11:31:25 EDT 2007
Hi everybody,
i solve the problem, it seems to be a wrong path in the images directory.
Thanks a lot .
Rubén P.
2007/6/28, Christian López Espínola <penyaskito at gmail.com>:
> I can't reproduce the bug with a example.
> What browser are you using? Do the problem occurs in other browsers?
> I can add that in my application i'm using XHTML Strict, but I think
> that using HTML 4 mustn't be a problem.
> Cheers from the hot Seville :)
> On 6/28/07, Ruben Pardo <correosig at gmail.com> wrote:
> > Hi,
> > I'm checking my html source generated but it doesn't work. I'm using
> > OpenLayers 2.4 API, and still have the same problem. When i remove the
> tag
> > <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "
> > http://www.w3.org/TR/html4/loose.dtd" > it works fine.
> > My code  :...........
> > <html >
> >     <head>
> >         <meta content="text/html;charset=ISO-8859-1"
> > http-equiv="Content-Type">
> >     </head>
> >     <body onload="init();"  >
> >      <style type="text/css">
> >         #map {
> >             width: 800px;
> >             height: 500px;
> >             border: 1px solid black;
> >            </style><script src="js/lib/OpenLayers.js"
> > type="text/javascript"></script> <script
> > type="text/javascript" >
> >                var map,layer;
> >          function init(){
> >            map = new OpenLayers.Map('map', { controls: [],tileSize: new
> > OpenLayers.Size(500,500) });
> >           layer = new OpenLayers.Layer.MapServer( "OpenLayers WMS","
> http://192.168.212.20:84/cgi-bin/mapserv.exe?map=/ms4w/apps/prbmosaico/htdocs/prbmosaico.map
> ",{layers:
> > 'PARCELASDE', TRANSPARENT: 'true'},{ maxExtent: new
> > OpenLayers.Bounds(186555.49,4136068.22,211516.81,4156763.12),
> maxResolution:
> > 104} );
> >            map.addControl(new OpenLayers.Control.PanZoomBar());
> >            map.addControl(new OpenLayers.Control.MouseToolbar ());
> >            map.addControl(new OpenLayers.Control.OverviewMap());
> >            map.addLayer(layer);
> >                     if (!map.getCenter())
> >                        map.zoomToMaxExtent();
> >         </script>
> >       <div style="margin:0px" id="map"></div>
> > </body>
> > 2007/6/28, Christian López Espínola < penyaskito at gmail.com>:
> > > Hola Ruben,
> > > The doctype mustn't be a problem with OpenLayers. I'm using ASP.NET
> > > with OpenLayers and I hadn't any problem.
> > > Please check the HTML source generated by your application and if you
> > > can't find the solution, post a piece.
> > > Hope this helps
> > > > Hi everybody,
> > > > I've got a problem  showing controls with OpenLayers when i put a
> > doctype on
> > > > my html page.
> > > > I'm integrating OpenLayers in a custom jsf component, that
> autogenerate
> > the
> > > > DOCTYPE.
> > > > It shows me the layers, but not the controls over the layers
> > (PanZoomBar,
> > > > Overview, etc...)
> > > > It works fine when i remove the doctype in the generated code.
> > > > ¿how can i solve this?
> > > > Thanks a lot in advance
> > > > My generated code is ...
> > > > "http://www.w3.org/TR/html4/loose.dtd" >-->
> > > > <html >
> > > >     <head>
> > > > </head><body onload="init();">
> > > >         #map {
> > > >             width: 800px;
> > > >             height: 500px;
> > > >                var map,layer;
> > > >          function init(){
> new
> > > > WMS","
> > > > ",{layers: 'PARCELASDE', TRANSPARENT: 'true'},{ maxExtent: new
> > maxResolution:
> > > > 104} );
> > > >                        map.zoomToMaxExtent ();
> > > >         </script>
> > > >       <div  id="map"></div>
> > > >        </body>
> > > > _______________________________________________
> > > > Users mailing list
> > > > Users at openlayers.org
> > > > http://openlayers.org/mailman/listinfo/users
> > > Regards,
> Regards,
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070628/48acf436/attachment.html
