[OpenLayers-Users] Is it possible to completely change the projection of a Map?
Nick Whitelegg nick at hogweed.org
Mon May 7 07:01:47 EDT 2007
Hello everyone,
As part of an OpenStreetMap editing application I'm doing, I would like to be
able to replace not only the layers but also the projection of the base map.
The application is a point-of-interest editor for OpenStreetMap, it allows
users to use the OpenLayers Vector layer to trace the outlines of lakes and
woods and also add POIs like hill summits. I want users to be able to switch
between two base layers.
The two base layers comprise Freemap (OpenStreetMap rendering client) which is
projected in Mercator, and the New Popular Edition (old Ordnance Survey maps
of the UK) which has the OSGB36 projection.
At the moment I use a combination of PHP (i.e. completely reload the page from
the server) and openlayers JS code to deal with the switch. In other words,
the Map object created depends on a query string value. Can I instead do it
all within OpenLayers without necessitating a page reload?
My current code is as below (the variable "basemap" ultimately derives from a
query string value, and "converter" is a class I've written to deal with
conversion between projections).
            if (basemap=="npe")
                cvtr = new converter("OSGB");
                /* NPE BEGIN  */
                map = new OpenLayers.Map('map',
                { maxExtent: new OpenLayers.Bounds (0,0,599999,999999),
                maxResolution : 8,
                units: 'meters' }
                base = new OpenLayers.Layer.WMS( "New Popular Edition",
                {'layers': 'npe'},{buffer:1} );
                // main freemap maps
                cvtr = new converter("Mercator");
                resolutions: [10],
                tileSize: new OpenLayers.Size(500,500),
                      units: 'meters' }
                base = new OpenLayers.Layer.WMS( "Freemap/Mapnik",
                            {buffer:1} );
