[OpenLayers-Users] Selecting Text from Popup
Lee Keel
lee.keel at uai.com
Wed May 9 15:45:20 EDT 2007
Christopher,
If you are talking about the '-moz-user-select', then is there a way to
override this css just for the div.olPopupContent? I tried setting it equal
to 'all' in my css, but still no luck in getting it to allow selection. Is
there any other way around this? I really need to be able to allow the user
to select from this popup so that they can paste the contents into an email
or word document.
Also, another question on the styling of the popup. My text may extend past
the end of the popup size. So, I was hoping that I could set
overflow:scroll; and that would put a scroll bar on the popup, but that
didn't work. Can you tell me if it is possible to add a scrollbar to the
popup?
Thanks again.
Lee
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Wednesday, May 09, 2007 1:02 PM
To: Lee Keel
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Selecting Text from Popup
On Wed, May 09, 2007 at 12:41:37PM -0500, Lee Keel wrote:
> Is there a way for a user to copy text from the anchored bubble onto the
> clipboard? I have looked at the Popup code and it looks like there is
code
> in there specifically for selecting the text, but I can't seem to get it
to
> select the text, even on the example pages.
There is CSS in default/style.css to prevent selection inside the map.
This (due to cascading) also applies to popups.
Regards,
Christopher Schmidt
MetaCarta
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
