[OpenLayers-Users] Display Map from MapServer with OpenLayers
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Thu May 10 08:12:55 EDT 2007
You can do this with the OpenLayers.Layer.MapServer.Untiled(...) object.
THere might be a WMS.Untiled() layer also that you can use.
-Steve
Pfirter Lukas wrote:
> I just got this work, thank you!
> I needed to implement the following code:
> * var wmslayer = new OpenLayers.Layer.WMS( "WMS Layer", " **
> http://domain.com/cgi-bin/mapserv?map=/path/to/file.map *
> <http://domain.com/cgi-bin/mapserv?map=/path/to/file.map>* ", {layers:
> 'Layername'} ); *
> * map.addLayers([wmslayer]); *
> Now, the only problem I have left is, that the distance measuring bar,
> sended by the mapserver, is displayed a few times inside the OL window.
> Is it possible to still use this dynamically generated bar with OL but
> have it displayed only once (for example in a corner)? Or do I have to
> disable this bar in the ".map"-File and can not use it in OL?
> Lucas
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [ mailto:users-bounces at openlayers.org
> <mailto:users-bounces at openlayers.org> ] Im Auftrag von Barend Köbben
> Gesendet: Mittwoch, 9. Mai 2007 16:57
> An: Users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Display Map from MapServer with OpenLayers
>  >Try this instead:
>  >layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>  >" http://domain/cgi-bin/mapserv?map=/path/to/project.map
> <http://domain/cgi-bin/mapserv?map=/path/to/project.map>
>  >< http://domain/cgi-bin/mapserv?map=/path/to/project.map
> <http://domain/cgi-bin/mapserv?map=/path/to/project.map> > ", {layers:
>  >'basic'} );
> ...or, if you need SLD based stylings (as I did):
> <http://domain/cgi-bin/mapserv?map=/path/to/project.map> <
> {layers: "landcover",
>      SLD: "url-to-your-SLD <
> http://geoserver.itc.nl/mapserver/sld/galicia.xml
> <http://geoserver.itc.nl/mapserver/sld/galicia.xml> > "}
> ...and if you want the layer to be an overlay iso. a base layer:
> <http://geoserver.itc.nl/mapserver/sld/galicia.xml> > ",
>      format: "image/png",
>      transparent: "true"}
> Barend Köbben
> International Institute for Geo-information Sciences and  Earth
> Observation (ITC) PO Box 6, 7500AA Enschede (The Netherlands)
> ph: +31-(0)534874253; mobile: +31-(0)622344955
> Users mailing list
> http://openlayers.org/mailman/listinfo/users
> <http://openlayers.org/mailman/listinfo/users>
> Users mailing list
