[OpenLayers-Users] Vertical lines on WMS layer?
Christopher Schmidt crschmidt at metacarta.com
Wed May 23 16:55:39 EDT 2007
On Wed, May 23, 2007 at 04:19:37PM -0400, Jeff Yutzler wrote:
> When I set the following WMS layer into OpenLayers:
>    map.addLayer(new OpenLayers.Layer.WMS( "IONIC Natural Earth WMS",
> "http://demo.ionicenterprise.com/ionicweb/map/NATURALEARTH", {layers:
> 'NATURALEARTH'}));
> I get behavior I have not seen anywhere else.  At most scales, the layer
> looks fine.  However, at 1:3M and 1:7M, white vertical lines appear at
> the tile boundaries.  I suppose this is a defect in OpenLayers, but I'm
> not really even sure how to describe it.  Any ideas?
I doubt it's an OpenLayers defect. I expect that your WMS server is not
coping so well. A way to test this would be to right click on an image,
copy the URL, and put it in an HTML page with a red background. If you
can see a white pixel along the edge of the tile, you're dealing with a
problem on your WMS server.
I just tried this with an empty HTML file:
<body bgcolor="red"><img
src="http://demo.ionicenterprise.com/ionicweb/map/NATURALEARTH?LAYERS=NATURALEARTH&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=0%2C39.375%2C5.625%2C45&WIDTH=256&HEIGHT=256"
/></body>
And I see a white line.
So, go back to your WMS server, and get them to fix it :)
Alternatively, use TileCache with metatiles. The buffer will hide this
defect from you.
Regards,
Christopher Schmidt
MetaCarta
