[OpenLayers-Users] GeoRSS : new features ?
Christopher Schmidt crschmidt at metacarta.com
Thu May 24 07:40:02 EDT 2007
On Thu, May 24, 2007 at 12:41:28PM +0200, Fran?ois Prunayre wrote:
> Hi list,
> Working on the web interface of GeoNetwork (metadata catalog for geospatial
> information), we added some features to OpenLayers GeoRSS layers.
> Changes are :
> - added item agregation (if more than one item is located on the same place,
> the popup is filled with description of all items). The icon size increase
> according to the number of items
> - added support for georss:box element. A point is created on the UL corner
> of that item. A boxe is added to a boxes layer. You have one layer with
> markers and one layer with boxes.
> - added georss extent property (use to zoom to layer)
> - added popup width and height property.
> - added trigger event loadend
> A demo inside GeoNetwork is available here :
> http://dev.sandre.eaufrance.fr/gnopenlayers/ (you could search for nitrate
> or bassin for example)
> I will be pleased to send that to one of the committers if you think that
> could be added to openlayers (I'm new to openlayers and I'm not really aware
> of who is working on what !). If you think that there's some stuff to adapt,
> feel free to comment.
If you can follow the instructions on 'Submitting code' under
http://trac.openlayers.org/wiki/HowToContribute -- open a ticket, upload
a patch, sendin a CCLA, etc. -- that'd be great. Note that patches with
tests get pulled in faster, so if you can work on writing tests, that
helps too.
The patch you've created definitely sounds useful, so please do bring it
in.
Regards,
Christopher Schmidt
MetaCarta
