[OpenLayers-Users] GeoRSS layer changes it name randomly
Christopher Schmidt crschmidt at metacarta.com
Tue May 29 17:58:39 EDT 2007
On Tue, May 29, 2007 at 03:33:14PM -0600, Gregor Mosheh wrote:
> Hiya. :)
> I'm experiencing an odd behavior, which I suspect to be a bug.
> This map has a GeoRSS layer and popup markers. In the layer controller
> widget, the RSS layer's name will change spontaneously, which it
> definitely should not be doing.
It's not spontaneously: when the layerswitcher redraws (when you change
a layer visibility, for example), it updates the name from a heuristic
based on the URL to being the first 'title' element in the feed.
> Should I file this as a bug, or is this supposed to happen?
Yep, it should be filed as a bug.
Regards,
Christopher Schmidt
MetaCarta
