[OpenLayers-Users] Meta layer and Partial labels
Stephen Woodbridge
woodbri at swoodbridge.com
Thu May 31 00:13:59 EDT 2007
Jackey Cheung wrote:
> Greetings.
> using meta layers helps me combat the edges effects, but after I used
> meta layers, labels are broken. many of the labels are partially
> invisible at the edge of tiles. is there any way to fix this issue? do I
> have to separate the labels into a different layer?
If you are using mapserver to generate the images, set PARTIALS FALSE in
the LABEL block.
-Steve W
