[OpenLayers-Users] strange click events with internet explorer
Christopher Schmidt crschmidt at metacarta.com
Thu May 31 10:21:51 EDT 2007
On Thu, May 31, 2007 at 11:00:08AM +0200, Christian Sengstock wrote:
> Is this a known problem and is there maybe a workaround? I think the
> problem depends on where the map div is located in the DOM, because it
> worked properly when i tested the MouseToolbar with a very basic html
> page (just the map div).
I'm not aware of this problem, or a workaround. (This just means I
haven't run into it, largely because I mostly use simple DOMs :))
Anyone else run into this issue?
Regards,
Christopher Schmidt
MetaCarta
