[OpenLayers-Users] Tiles removed too early
Kevin Kempfer mail at kevinkempfer.de
Thu May 31 14:38:56 EDT 2007
Hello,
when I drag the map to the north, the tiles on the bottom edge of the
screen are removed before they are outside the viewport. Dragging the
map to the south is the same effect: The tiles are loaded too late. In
both cases, there's whitespace visible.
This only applies to north/south dragging, east/west is OK! The same
happens when clicking on the navigation icons, so it should not be a
problem with the mouse dragging feature.
Is the a way to avoid this behaviour?
Thanks,
Kevin.
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070531/24b9adf1/smime.bin
