[OpenLayers-Users] editingtoolbar position in custom application
R. Ortner reinhard.ortner at edu.fh-kaernten.ac.at
Mon Nov 5 05:12:09 EST 2007
I actually made it work for the LayerSwithcher by deactivating a few
parameters in the LayerSwitcher.js:
//this.div.style.top = "100px"; //25px default
//this.div.style.right = "0px";
in the html page:
#layerswitcher {
            width: 24.7%;
            height: 70%;
            border: 0px solid black;
	    top: 100;
	    left: 0px;
now i have to find this for the editingtoolbar
R. Ortner wrote:
> Hi,
> i tried to implement the editingtoolbar-outside example into my
> application.
> Basically it worked to put the toolbar outside my map but the toolbar is
> displayed on the top right of my html page. How/Where can i change that? I
> expected that the position is managed by the style section with
> .olControlEditingToolbar, but changes there have no effect!
> here is my html code for the toolbar:
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
> <html xmlns="http://www.w3.org/1999/xhtml">
>   <head>
>   <link rel="stylesheet"
> href="/usr/share/openlayers-2.5/theme/default/style.css" type="text/css"
>     <style type="text/css">
> 		.olControlEditingToolbar  {
>             float:left;
>             right: 0px;
>             height: 30px;
>             width: 150px;
>         #map {
>             width: 800px;
>             height: 500px;
> 			position: absolute;
>             top: 40;
>             right: 25%;
> 			<!-- float:center; -->
> 		#layerswitcher {
>             width: 25%;
>             height: 60%;
>     </style>
>     <script
> src="http://172.21.18.45/openlayers/lib/OpenLayers.js"></script>
>     <script type="text/javascript">
>         var map;
>         function init(){
> 		    var options = { scales: [800000, 600000, 250000, 125000, 75000,
> 30000, 10000],
> 			'projection':'EPSG:31258', 'units':'m',
> 			'maxExtent': new OpenLayers.Bounds(390730, 119473, 594760, 238680),
> 			'maxResolution': "auto",
> 			controls: [new OpenLayers.Control.MouseDefaults()],
> 			layers: [l_wms],
> 			minRatio: 8,
> 			maxRatio: 128
> 			map = new OpenLayers.Map($('map'),options, { controls: [] });
> 			map.addControl(new OpenLayers.Control.PanZoomBar());
> 			map.addControl(new OpenLayers.Control.MouseToolbar());
> 					//map.addControl(new OpenLayers.Control.MousePosition());
> 					//map.addControl(new OpenLayers.Control.OverviewMap());
> 			map.addControl(new OpenLayers.Control.Scale());
> 			map.addControl(new
> OpenLayers.Control.LayerSwitcher({'div':OpenLayers.Util.getElement('layerswitcher'),
> activeColor:"red"}));
> 			map.addControl(new OpenLayers.Control.OverviewMap(options));
> 		//--------------- EditToolbar ---------------
> 		//	vlayer = new OpenLayers.Layer.Vector( "Custom Layer");
> 		//	map.addControl(new OpenLayers.Control.EditingToolbar(vlayer));
>             vlayer = new OpenLayers.Layer.Vector( "Editable" );
>             var container = document.getElementById("panel");
>             var panel = new OpenLayers.Control.EditingToolbar(
>                 vlayer, {div: container}
>             map.addControl(panel);
> 			//END ------- Edit Toolaber --------------
> // ------------------------------------------------------------ Layer
> 		// ---------------------------------- WMS
> 			var g_wms = new .....
> 			var l_wms = new .....
> 			var b_wms = new .....
> 			var lg_wms = new .....
> 			var l_st_wms = new .....
> 	//--------------- Define Layers -------------
> 			map.addLayers([l_wms, b_wms, g_wms, lg_wms, l_st_wms, vlayer]);
> 					//map.addControl(new OpenLayers.Control.LayerSwitcher());
> //LayerSwitcher Panel
>             map.zoomToMaxExtent();
>     </script>
>   </head>
>   <body onload="init()"; style="color: rgb(0, 0, 0); background-color:
> rgb(0, 0, 0);">
>   <!--  <h1>Orthophotos</h1> -->
>     <div id="layerswitcher" style="float:center;"></div>
> 	<div style="margin-left: 20%;" id="map"; ></div>
> 	<div id="panel" class="olControlEditingToolbar"></div>
>   </body>
> </html>
> I have a similar problem with the layerswitcher outside the map, it is
> also displayed on the right of my application but the layerswitcher change
> the position when I make changes in the style section (but the background
> of the layer allways remain on the right side of the html page)
View this message in context: http://www.nabble.com/editingtoolbar-position-in-custom-application-tf4750311.html#a13584094
