[OpenLayers-Users] VERY strange behaviour = bug?
Frédéric Junod frederic.junod at camptocamp.com
Wed Nov 14 04:52:10 EST 2007
In http://geoserver.itc.nl/mapserver/OpenLayersBugLocal.html, the css style
sheet (http://geoserver.itc.nl/OpenLayers25/theme/default/style.css) can't be
found.
I guess you did not copy the 'theme' directory.
http://trac.openlayers.org/browser/trunk/openlayers/readme.txt:
As an example, using bash (with the release files in ~/openlayers ):
$ cd /var/www/html
$ cp ~/openlayers/build/OpenLayers.js ./
$ cp -R ~/openlayers/theme ./
$ cp -R ~/openlayers/img ./
fredj
Le Wed, 14 Nov 2007 10:34:41 +0100,
Barend Köbben <kobben at itc.nl> a écrit :
> [version with working links on:
> http://geoserver.itc.nl/mapserver.OpenLayersBug.html]
> STRANGE BUG?
> when loading Openlayers 2.5 from a location other than the openlayers.org/api
> site, the OverviewMap's default location suddenly is upperleft iso.
> lower-right...
> *	Load map with openlayers.js script coming from openlayers.org/api
> hosted site <http://geoserver.itc.nl/mapserver/OpenLayersBugHosted.html> ...
> => control is in lower-right
> *	Load map with openlayers.js script coming from this site
> <http://geoserver.itc.nl/mapserver/OpenLayersBugLocal.html> ... => control is
> in upper-left, overlapping the zoom/pan tools
> Even stranger, it worked OK in OpenLayers 2.4
> <http://geoserver.itc.nl/mapserver/OpenLayersBugLocal24.html> ...
> I'd consider this a bug, or is it something else...?
Frédéric Junod
Camptocamp SA
