[OpenLayers-Users] Changing Resolution in Spherical Mercator
Linda Rawson linda.rawson at gmail.com
Fri Nov 16 09:17:59 EST 2007
I am using the following to define my map:
options = {
    projection: "EPSG:900913",
    units: "m",
    maxResolution: 156543.0339,
    numZoomLevels: 18,
    maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
                                     20037508, 20037508.34)
map = new OpenLayers.Map('map',options);
Then my layer:
var sat = new OpenLayers.Layer.Google(
                "Google",
                {'sphericalMercator': true}
What the sphericalMercator true does is run the
initMercatorParameters: function() {
        // set up properties for Mercator - assume EPSG:900913
        this.RESOLUTIONS = [];
        var maxResolution = 156543.0339;
        for(var zoom=0; zoom<=this.MAX_ZOOM_LEVEL; ++zoom) {
            this.RESOLUTIONS[zoom] = maxResolution / Math.pow(2, zoom);
        this.units = "m";
        this.projection = "EPSG:900913";
The maxResolution of 156543.0339 is based on (20037508.34 + 20037508) / 256.
I need a different Resolution but I still want the forward and inverse
mercator functions to work.  Where are all the different places to change
the resolution?  I need it based on a tile that is not 256 in size.  I have
tried changing this in initMercatorParameters, the map, but It still does
not seem to play nice.
Thanks,
Linda Rawson
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071116/7680d5f0/attachment.html
