[OpenLayers-Users] error in resolution index from tilecache/geoserver
Christopher Schmidt crschmidt at metacarta.com
Sun Nov 25 20:10:00 EST 2007
On Sun, Nov 25, 2007 at 06:30:27PM -0600, Lance Dyas wrote:
> I am getting error of this sort from tilecache...
> images are causing this..
The most important thing to do is to ensure that the OpenLayers Layer
has the same resolutions and bounding box as your TileCache layer. You
can define the resolutions in OpenLayers via the 'resolutions' option or
the 'maxResolution' option on the layer. The maxExtent should be defined
to match the bbox parameter of the TileCache layer.
If you are using TileCache for overlays, you should set the 'reproject'
option on the layer to 'false'.
Regards,
Christopher Schmidt
MetaCarta
