[OpenLayers-Users] Adding new zoombar control?
Christopher Schmidt crschmidt at metacarta.com
Thu Nov 29 15:15:46 EST 2007
On Thu, Nov 29, 2007 at 12:09:51PM -0800, samd wrote:
> No Chris, there is more then this I understand that otherwise I would not be
> able to produce a map in the first place. I was showing you that a simple
> option of adding the numZoomLevels produced pink tiles.
> When adding the following controls:
> map.addControl(new OpenLayers.Control.PanZoomBar({zoomWorldIcon:true}));
> map.addControl(new OpenLayers.Control.MouseToolbar());
> map.addControl(new OpenLayers.Control.LayerSwitcher({'ascending':false}));
> map.addControl(new OpenLayers.Control.Permalink());
> map.addControl(new OpenLayers.Control.MousePosition());
> map.addControl(new OpenLayers.Control.OverviewMap());
> map.addControl(new OpenLayers.Control.KeyboardDefaults());
Still no Layer. Still not enough information for me to cause blank tiles
to appear in any of the examples.
Full HTML for an example which causes pink tiles. Put it online or
attach it to an email. Then maybe someone can help you.
Regards,
Christopher Schmidt
MetaCarta
