[OpenLayers-Users] z order of pan zoom controls
Michael Quentel mquentel at rim.com
Mon Oct 1 18:25:01 EDT 2007
Many thanks to Brad for his suggestion to create a separate controls
div...very impressive demo.
However, it turns out that the issue was caused by OL not being able to
see the images directory because of the way it was attempting to
reference the images (of the zoombar, etc) from a JSP.  Correcting the
image path in Utils.js solved this.
One helpful tip to anyone working with JSPs and OL: during development,
include code to prevent the page from being cached; this will help
ensure your javascript changes will be present.  Include the code below
for development in your JSP; remove it for production release.
response.setHeader("Cache-Control","no-cache");
response.setHeader("Pragma","no-cache");
response.setDateHeader ("Expires", 0);
Cheers,
Mike Quentel
-----Original Message-----
From: bradleyspencer [mailto:brad at cubewerx.com.au]
Sent: Thursday, 27 September 2007 18:28
To: Michael Quentel; users at openlayers.org
Subject: RE: [OpenLayers-Users] z order of pan zoom controls
Michael,
I position the zoom controls 'off map' so that I get maximum map
real-estate.
I do this with a Div and I presume you can do the same and also set a
z-index in the styles for that Div (I have not done it though).
map.addControl(new
OpenLayers.Control.PanZoomBar({div:$('zoomControl')}));
Anyway, see my example at http://demo.cubewerx.com.au/retirement.html
Hope this helps.
Cheers,
Brad Spencer
[mailto:users-bounces at openlayers.org]On
Behalf Of Michael Quentel
Sent: Friday, 28 September 2007 12:38 AM
To: users at openlayers.org
Subject: [OpenLayers-Users] z order of pan zoom controls
Please, where do I change the z order of the pan zoom controls?  I
developed a custom client that consumes a proprietary map service (in a
WMS-like manner, based on the WMS Untiled code--thank you for this
example), but the map image seems to be getting drawn on top of the pan
zoom controls.  I think this is happening because I briefly see the
controls appear just before the map appears.
Thank you.
Mike Quentel
This transmission (including any attachments) may contain confidential information, privileged material (including material protected by the solicitor-client or other applicable privileges), or constitute non-public information. Any use of this information by anyone other than the intended recipient is prohibited. If you have received this transmission in error, please immediately reply to the sender and delete this information from your system. Use, dissemination, distribution, or reproduction of this transmission by unintended recipients is not authorized and may be unlawful.
