[OpenLayers-Users] GML lines not located correctly in y axis
Christopher Schmidt crschmidt at metacarta.com
Tue Oct 2 16:50:03 EDT 2007
On Tue, Oct 02, 2007 at 09:44:12PM +0100, Richard Thurbin wrote:
> I am creating a bunch of GML files and pointing them at open layers to
> draw lines over a map. The lines are being drawn Ok but when you pan
> up, the location the lines are on the map does not move the same amount
> as the map. Also the lines at the top and bottom of the map do not
> follow the roads that the location references give (where as the ones
> in the middle do).<br>
Drawing vectors over Google only works in 2.5, and only works with
sphericalMercator turned on (so you will need to reproject your GML
files to the SphericalMercator projection, aka EPSG:900913).
Regards,
Christopher Schmidt
MetaCarta
