[OpenLayers-Users] How to overwrite OpenLayers.Format.KML
Arnd Wippermann
arnd.wippermann at web.de
Thu Oct 4 09:15:31 EDT 2007
I want to display kml-files in SphericalMercator on google maps. kml-files
works with lon-lat-values, so I have to reproject the data. With the
functionality of OpenLayers it's no problem.
Problem is:
I don't know how to overwrite the OpenLayers.Format.KML-class before
creating the layer. I want to change the functions
point: function(node) {...
linestring: function(node, ring) {...
to insert some stuff for reprojecting the data from EPSG:4326 to
EPSG:900913. Also I need 2 new properties in the Class:
fromEPSG, toEPSG.
OpenLayers.Format.KML.prototype.point = function(){... didn't work, neither
set a new property with OpenLayers.Format.KML.fromEPSG.
So I have copied the whole class, changed the name of the class, entered my
stuff. To choose between klmns 2.0 and 2.1 I have a second copy with only
change for the klmns.
My code to call the functions looks like
if(kmlVersion==20)
var parseKMLx = OpenLayers.Format.KMLx;
else
var parseKMLx = OpenLayers.Format.KMLx21;
map.addLayer(new OpenLayers.Layer.GML("KML " + (++kmlCounter), mykml,
{format: parseKMLx}));
The loading of KML-files in EPSG:4326 and reprojecting them to EPSG:900913
works great!
Question : Is there a better way to establish this behaviour without copy
the class two times.
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
