[OpenLayers-Users] what part of the API handles mouse drag panning?
Michael Quentel mquentel at rim.com
Thu Oct 4 11:39:07 EDT 2007
What part of OL API would I find the code (actual class and function)
pertaining to panning on mouse drag (when user does mouse down on map,
then drags mouse, then releases mouse, causing map to pan).  I'm
especially interested in finding the code that triggers another request
for a new tile or set of tiles from the server upon mouse drag.  I can
read the code, but if someone can point me in the right direction, it
would help me a lot.
Many thanks.
Mike Quentel
This transmission (including any attachments) may contain confidential information, privileged material (including material protected by the solicitor-client or other applicable privileges), or constitute non-public information. Any use of this information by anyone other than the intended recipient is prohibited. If you have received this transmission in error, please immediately reply to the sender and delete this information from your system. Use, dissemination, distribution, or reproduction of this transmission by unintended recipients is not authorized and may be unlawful.
