[OpenLayers-Users] GUI frameworks
Brent Pedersen
bpederse at gmail.com
Fri Oct 5 12:56:32 EDT 2007
to add to the mix:
after tinkering with most major frameworks (not Jx, that looks
interesting) i've settled on jQuery and yahoo's YUI depending on the
project.
jquery just released the UI library so it's still a bit rough, but now
there are _lots_ of developers and users so things get fixed quickly.
i guess you'll have to decide whether you like the jQuery syntax, i
find it very powerful and clear. some do not. it also has the most
accomodating license(s) if that's an issue.
YUI is very stable, great docs, and lighter than dojo. the syntax is
more verbose than jQuery, but quite clear. plus, yahoo hosts the
files:
http://developer.yahoo.com/yui/articles/hosting/
with proper caching and compression headers so library size is less an issue.
-b
On 10/1/07, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> Hi list,
> I just read on Sean Gillies' blog that Cartoweb 4 has chosen Dojo to build
> applications around OpenLayers.
> I am also in the phase of choosing a GUI js framework, and for me it seems
> Ext JS is the best choice (http://www.extjs.com), but then again it seems a
> shame to be working on several frameworks once again ....
> Can anybody (from the Cartoweb team) elaborate on the choice for Dojo?
> Or can other people share their experiences with similar frameworks? I saw
> for instance that DMSG's Fusion has written their own UI library, what are
> the reasons behind that?
> Thanks in advance. Hope to get some lively discussion on this subject.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
