[OpenLayers-Users] Markers with popup
petey1815 lootens.pieter at gmail.com
Fri Oct 5 17:10:49 EDT 2007
I'm using a similar way to produce markers & popup text on my maps.
I'm using the OpenLayers for an online game & am allowing users to move
their pieces. A php-script updates the DB & generates CSV-files, that are
then loaded into the OpenLayers map.
This works fine, but if i use the same filename (eg units.txt), it doesn't
refresh correctly. This probably is a problem with the refresh setting of
the server, but i was wondering if anyone created a script to create popup &
markers from variables.
Any help would be appreciated.
cheers
View this message in context: http://www.nabble.com/Markers-with-popup-tf2925480.html#a13038246
