[OpenLayers-Users] How connect the editing toolbar to a layer
on the fly
Pierre GIRAUD
bluecarto at gmail.com
Fri Oct 5 18:30:52 EDT 2007
I don't really know how you added buttons to the existing toolbar, but
you might want to have a look at the panel control.
This would allow you to build your own toolbar, including the controls you need.
http://openlayers.org/dev/examples/panel.html
And, as editingToolbar is "a" panel, you can also add controls to it :
var p = new OpenLayers.Control.EditingToolbar(vlayer);
p.addControls(new OpenLayers.Control.SelectFeature(vlayer, {'multiple':true}));
Regards
On 10/4/07, Arnd Wippermann <arnd.wippermann at web.de> wrote:
> In parts I have managed in a easy way to swap the control from one layer to
> another.
> editControl.destroy();
> var lyr = map.layers[AktLyr];
> editControl = new OpenLayers.Control.EditingToolbar(lyr);
> map.addControl(editControl);
> But I have used the editingtoolbar.js, have it modified to insert a button
> for selectFeature and modifyFeature.
> When I first add the toolbar to the "Editable" layer, all buttons work. When
> I swap to another layer, it works also. But when I swap a second time the
> two added buttons works for the previous layer and not for the new one. This
> means, I can draw features on one layer, but I'm not able to select this
> features.
> Mit freundlichen Grüssen
> Arnd Wippermann
> http://gis.ibbeck.de/ginfo/
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Tim Schaub
> Gesendet: Donnerstag, 4. Oktober 2007 21:41
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] How connect the editing toolbar to a layer
> on the fly
> Hey-
> Christopher Schmidt wrote:
> > On Thu, Oct 04, 2007 at 03:28:19PM +0200, Arnd Wippermann wrote:
> >> Is there a way to connect the editing toolbar to a specific layer on
> >> the fly.
> > Doesn't look like it. It looks like you could break the abstraction
> > barrier, dive in, and change the layer property on each of the
> > controls
> > -- if you weren't editing at the time, that might work. I'm not sure.
> This should be made easier.
> If you want to see how I've done it, take a look at the (not for production,
> not to be considered stable, for demonstration purposes
> only) FeatureEditor control with a change layer method:
> http://trac.openlayers.org/browser/sandbox/tschaub/wfsv/lib/OpenLayers/Contr
> ol/FeatureEditor.js#L162
> All that should be cleaner. Basically, you need a way to swap out the
> handler that the draw/modify controls use.
> Tim
> > Regards,
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
