[OpenLayers-Users] MapServer to OpenLayers line rendition
Christopher Schmidt crschmidt at metacarta.com
Sun Oct 7 22:06:51 EDT 2007
On Mon, Oct 08, 2007 at 09:25:27AM +0800, Aileen wrote:
> Hi Steve!
Aileen:
Your email would be more readable for me if you didn't use HTML email --
you should see if you can tell your mail client not to do that. (I only
say this because I had to do a fair amount of work to actually see this
email as you meant it due to the HTML stuff.)
> var myqry = new OpenLayers.Layer.MapServer.Untiled("Map", "/cgi-bin/mapserv?", {map: '/hometo/maps/mymap.map', layer:'#qrylayer#', map_#qrylayer#_classitem:'#qryitem#', map_#qrylayer#_class_expression:'#q.code#', layers:"#onlayer#", format: 'gif', transparent:'false'});
The URl actually being passed to MapServer, which is, I believe, the one
that matters, is:
http://203.131.125.60/cgi-bin/mapserv?map=%2Fhome%2Fmapsfinal%2Fmaps%2Flonlat.map&layers=&format=gif&transparent=false&numZoomLevels=10&mode=map&map_imagetype=png&srs=EPSG%3A4326&mapext=121.011138%2014.626299%20121.045862%2014.651101&imgext=121.011138%2014.626299%20121.045862%2014.651101&map_size=700%20500&imgx=350&imgy=250&imgxy=700%20500
Hm, looking at what you're syaing, that doesn't make sense -- I'm
looking at the code in
http://203.131.125.60/GoogleApi/OpenLayersSVN/mapOL.cfm?type=&ids=60738,60739,60740,79907&mypoint=&clickmap=&click_x=&click_y=&olfile=MOL2007-10-08-10:01:03&mzoom=&mcenter=&current_extent=&name=Quezon%20Avenue&location=Quezon%20Cityi&userid=
and it doesn't match the layer creation you mention above: instead, it
says:
mcmap = new OpenLayers.Layer.MapServer.Untiled("Map",
  '/home/mapsfinal/maps/lonlat.map', layers:'base', layers:"",
  format: 'gif', transparent:'false', numZoomLevels:'10'});
Where am I going worng?
Regards,
Christopher Schmidt
MetaCarta
