[OpenLayers-Users] Look who's using OpenLayers....
Richard Thurbin
richard.thurbin at cloudamber.com
Tue Oct 9 13:27:35 EDT 2007
Hi Pierre.
I have found text layers to be pretty slow past 100 points and have moved to using a raster later.
How many points are you using?
Richard Thurbin +44 7917 704 145 www.cloudamber.com
Sent from BlackBerry® wireless device
-----Original Message-----
Date: Tue, 9 Oct 2007 18:32:03
To:bitner at gyttja.org
Cc:users at openlayers.org
Subject: Re: [OpenLayers-Users] Look who's using OpenLayers....
Hum, I disagree with you.
The markers info is loaded once, and you can then navigate the map
easily without having to load anything but the baseLayer tiles.
With a raster layer for the pushpins, you would have to load the tiles
while navigating the map.
So I think that with their approach they save bandwidth, and they
increase usability for the final user.
Pierre
On 10/9/07, David William Bitner <david.bitner at gmail.com> wrote:
> Although, given the fact that they are not using any mouseover or clicky
> actions on the points, there really is no reason they should be doing the
> pushpins as a vector layer rather than serving it up as a raster somehow.
> On 10/9/07, Erik Uzureau <erik.uzureau at metacarta.com> wrote:
> > Right. A big OL Map should load right on the home page, with a bunch
> > of pushpins in it showing from where people have donated. They're
> > using TileCache too, fwiw :-)
> > erik
> > On 10/9/07, Espen Isaksen < espen.isaksen at gmail.com> wrote:
> > > They are using OpenLayers on the opening page.
> > > Espen
> > > On 09/10/2007, Barend Köbben < kobben at itc.nl> wrote:
> > > > Can't seem to find any info about that on your link. If I go to the
> 'serach'
> > > > page I get an empty box and a JS error:
> > > > id(engine) has no properties
> > > > [Break on this error] id(engine).className="active";
> > > > On 08-10-2007 19:48, "Erik Uzureau" <erik.uzureau at metacarta.com >
> wrote:
> > > > > http://creativecommons.org/
> > > > >_______________________________________________
> > > > > Users mailing list
> > > > > Users at openlayers.org
> > > > > http://openlayers.org/mailman/listinfo/users
> > > > Users mailing list
> > > Users mailing list
> > Users mailing list
> Users mailing list
Users mailing list
