[OpenLayers-Users] Problem with transparent PNG's and IE6
jonz jonathan.zaid at mediolanum.it
Wed Oct 10 10:53:38 EDT 2007
I don't know what your code was to generate the image nor do I understand
what was expected, but I too dealt with the transparent PNG IE6 "problem" in
the HTML content of a popup div. What I did was to convert every   tag
so for example
                 /img/OpenLayers/pop/ul.png
becomes
<DIV style="DISPLAY: inline-block; FILTER:
progid:DXImageTransform.Microsoft.AlphaImageLoader(src='/img/OpenLayers/pop/ul.png',
sizingMethod='scale'); WIDTH: 32px; HEIGHT: 9px"></DIV>
in the case that OpenLayers.Util.alphaHack() is true.
Don't know if this is the best way to do it, but it works for me.
ciao
jon
Glen Stampoultzis-2 wrote:
> I've got a bit of a problem with transparent PNG's in IE6.  I'm using
> the good old transparent PNG fix for IE 6 that is provided in
> OpenLayers.  This works great on my main map but I have a special
> customized popup that contains it's own little map and I get some very
> strange problems there.  Take a look at the following picture:
> http://farm3.static.flickr.com/2201/1530334012_e5301a8a3e_o.gif
> You can actually see right through all the div's to the main map where
> the icon is supposed to be transparent.  Sure I wanted transparent but
> not that transparent!
> I've been spending way too much time trying to figure this one out so
> I thought I'd see if anyone else has had similar problems.
> Hating IE6 more every day.
> Regards,
> Glen
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Problem-with-transparent-PNG%27s-and-IE6-tf4599029.html#a13137403
