[OpenLayers-Users] dynamic markers
Linda Rawson linda.rawson at gmail.com
Thu Oct 11 12:48:34 EDT 2007
I will tell you one thing...the dropdown list of icons is hard to find.  I
used the control here -> http://www.scbr.com/docs/products/dhtmlxCombo/
You probably want some kind of grid that is connected to the database.
There are many out there including Rico.  http://openrico.org/demos/livegrid
Linda Rawson
On 10/10/07, Tara Athan <tara_athan at alt2is.com> wrote:
> I should have been more specific in my question.
> I would like to create the textfile for the markers, titles and
> descriptions dynamically from a database so that users can enter new
> markers and they appear on the map with minimal intervention from me.
> I was planning to do this by the following steps
> 1. the user sees a map displaying the current markers from the text
> file, and an HTML form,
> 2. they click on the map to fill the lat lon fields in the form,
> 3.they type in the title, description and select characteristics from
> dropdown menus that determine the icon
> 4. PHP commands are used to enter this into a database (MySQL or
> PostGRES) on the server, along with an e-mail alert to the database admin
> 5. at regular intervals (i.e. daily), the text file is automatically
> updated from the database
> I now know how to do steps 1, 3 and 4 but I'm not so sure about 2 and
> clueless about 5.
> The example http://openlayers.org/dev/examples/google.html has controls
> that suggest it should be possible for user to add a marker to the map,
> but this example does not function for me (in Firefox 2.0.0.7, Windows
> XP SP2)
> I am hoping that someone has already implemented an example like this,
> or accomplished the same thing by a different method.
> I should mention that this would all be operating in a shared webhosting
> environment without root access.
> Thanks, Tara
> Linda Rawson wrote:
> > Tara,
> > For SQL Server,
> > Take a look at this
> > article...http://www.sqlteam.com/forums/topic.asp?TOPIC_ID=74882
> >  OR
> > You can set up an ODBC link and connect to that link via Excel to
> > produce a spreadsheet from which you could produce a text file.
> > Linda Rawson
> > On 10/9/07, *Tara Athan* <tara_athan at alt2is.com
> > <mailto:tara_athan at alt2is.com>> wrote:
> >     I did finally run across the documentation on the textfile format
> >     here:
> >     http://trac.openlayers.org/wiki/MapViewerService
> >     Thanks for your help- I have it working now.
> >     Also thanks for the tip about working in Excel (or OpenOffice ;-)
> >     )- it
> >     is actually possible to create the text file in notepad but you
> >     have to
> >     put the tabs in the right place and then they look the same as
> spaces,
> >     so it is very inconvenient.
> >     Working in a spreadsheet allows me to fill down for all the
> duplicate
> >     icons, sizes, etc. instead of typing them out.
> >     Now if I can just figure out how to get the textfile from a database
> >     query... anyone have an example of that?
> >     Tara
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071011/fef21832/attachment.html
