[OpenLayers-Users] OpenLayers in Rails
Arnd Wippermann arnd.wippermann at web.de
Thu Oct 11 14:19:12 EDT 2007
Hello Christopher,
Setting OpenLayers.Util.ImgPath = ... has no effect.
If you look at this, I would think there is "Util." missing:
OpenLayers.Util.getImagesLocation =
function () {
    return OpenLayers.ImgPath || OpenLayers._getScriptLocation() + "img/";
Setting OpenLayers.ImgPath = ... works.
Is there possibly a variable to set the path to the theme-dir as well?
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Christopher Schmidt
Gesendet: Donnerstag, 11. Oktober 2007 13:49
An: staff-gmail
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] OpenLayers in Rails
On Wed, Oct 10, 2007 at 11:55:04PM -0600, staff-gmail wrote:
> angus scown wrote:
> > staff-gmail wrote:
> >> The control icons are not showing up in Rails - I have
> >> OpenLayers.js from the build directory in the Rails javascripts
> >> folder  and put the /img and /theme also within the javascripts
> >> folder but they are not being accessed correctly.  The control
> >> buttons seem to work okay - but the images don't show.  Anyone work
around this ?
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > if you don't want to modify the openlayers javascript then you need
> > to place the /img folder in a folder with the controller name under
> > the public directory.
> > i.e. /public/some-controller-name/img e.g /public/jobs/img
> Michael Quentel wrote:
>  > Try modifying the image path in Utils.js to what the Rails
> application  > would use for the img and theme directories.
> thks - yeah, I saw that about the controller location.   Problem is if
> you use the map in more than 1 view, then you have the same image
> folders in multiple locations, not good though a hackable solution.   So
> it would be better to modify the Utils.js
Util.js provides the functionality to override the base image path, via the
OpenLayers.Util.ImgPath constant
(http://dev.openlayers.org/docs/files/OpenLayers/Util-js.html#Util.ImgPath
, not well enough documented).
Regards,
Christopher Schmidt
MetaCarta
Users mailing list
