[OpenLayers-Users] Google Style popup
Lance Dyas lancelot at inetnebr.com
Fri Oct 12 09:11:36 EDT 2007
Ofcourse I am also greedy and would  like to see tabbed popups with this..
Jachym Cepicky wrote:
> Hi,
> I just wanted to report that your nice Popup does not work with new
> OpenLayers 2.5 :-/
> Would it be possible to fix it and eventually publish patches?
> http://trac.openlayers.org/ticket/90 points to another example,
> http://labs.metacarta.com/Trinity/index.html which is not available :-/
> Thanks
> Jachym
> Daniel de la Cuesta píše v Čt 27. 09. 2007 v 20:34 +0200:
>> Hi,
>> I am newbie using Open Layers and I saw this sandboxed code in the
>> archives:
>> http://openlayers.org/pipermail/users/2007-August/002580.html
>> It was what I was looking for!.
>> I have checked it out and I am trying to show a the google style popup
>> when a marker is clicked:
>> marker1.events.register("mousedown", marker1, function(evt) {
>>     text = "hello"
>>     popup = new OpenLayers.Popup("olPopup",
>>                      new OpenLayers.LonLat(-4.549683, 36.737052),
>>                      new OpenLayers.Size(200,200),
>>                      texte,
>>                      true);
>>     markers.map.addPopup(popup);
>>   markers.addMarker(marker1);
>> The google popup works fine except:
>>      1. The position of the popup is not above the marker.
>>      2. When the popup it is outside the map it doesn´t pan.
>> I have tried the example from
>> http://svn.openlayers.org/sandbox/CloudAmber/Trunk/. In this example
>> the popup it is shown using the method "OpenLayers.Layer.Text" and
>> getting the information from text file. It works perfectly.
>> Am I doing something wrong or the Google popup doesn´t work fine if I
>> create it in the way explained above.
>> Thank you very much.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
