[OpenLayers-Users] vector selectFeatures: hover and onclick
Eric Lemoine eric.c2c at gmail.com
Sat Oct 13 16:45:05 EDT 2007
On 10/13/07, Josh Livni <josh at livniconsulting.com> wrote:
> I am wondering if there's an easy way to get a different effect for
> hover/mouseover and onclick for vector features.  For example, if I want
> to call functionH for a hover, and functionC for onclick.
You can try this:
select = new OpenLayers.Control.SelectFeature(vectorLayer, {
    callbacks: {
        click: functionC,
        over: functionH,
        out: functionO
By doing so note that:
 * you're going beyond the SelectFeature API, in other words things
could change from under your feet and your code could eventually fail
 * the provided callbacks override the default callbacks defined in
the select feature control, meaning you're totally on your own. For
example, no styling will be applied to the selected features.
> It seems that if I activate two SelectFeature for the same vector layer,
> one (the hover) seems to clobber the other (click)....
There seems to be an order issue. Try to activate "hover" first and then click.
Hope this helps,
Eric
