[OpenLayers-Users] google, yahoo maps + wms
Leandro R learonco at gmail.com
Fri Oct 19 09:45:27 EDT 2007
As far as I know set the option sphericalMercator:false on the Google layer,
and it will be display in lonlat.
Because commercial layers uses a spherical model of the Earth, they won't
line up correctly with you WMS layers in EPSG:4326, which uses an
ellipsoidal geometric model. You will see a shift between the layers.
I' ve solved this with GeoServer 1.6-beta3 and setting EPSG:900913 to the
map, so I send the request in this projection. Taking this way both layers
line up correctly.
Regards
2007/10/19, Armin Wäspy <armin.waespy at lubw.bwl.de>:
>  hi all,
> I'm currently working on an OL with a few WMS layers:
> http://rips-uis.lubw.baden-wuerttemberg.de/rips/wms_viewer/test/myOpenLayer.php
> like you can see the user has the possibility to select the base layer
> between google maps, ve or yahoo or others.
> the problem is that the wms layers are provided in EPSG 4326 and the
> projection of the commercial services (google...) are in whatever (EPSG:
> 900913). the point is i don't want (because i want to use wms where i don't
> have admin rights) to use the google projection.
> I found this in the list but i don't  know how i can do this in the right
> way.
> http://www.mail-archive.com/users@openlayers.org/msg00312.html
> any help?
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071019/a9459229/attachment.html
