[OpenLayers-Users] Routing Layer
Linda Rawson linda.rawson at gmail.com
Fri Sep 7 11:15:15 EDT 2007
Chris,
You remember that POI stuff we discussed?  That is sort of the thing that I
have to do.  Basically I read the data and create a vector layer with the
lines and then I create a marker layer.  They are tied together with a
change that Eric made proposed in the next release.  The layerswitched event
is what he customized.
// ***** Routes *****
markerRouteLayer = new OpenLayers.Layer.Markers("Routes");
vectorRouteLayer = new OpenLayers.Layer.Vector("RouteLines");
markerRouteLayer.events.register('layerswitched', vectorRouteLayer,
function(e) {
vectorRouteLayer.setVisibility(markerRouteLayer.getVisibility());
vectorRouteLayer.displayInLayerSwitcher = false;
GetRouteItems(PassID);
map.addLayer(vectorRouteLayer);
map.addLayer(markerRouteLayer);
----------------------------------------------------------- Ajax Calls or in
my case .Net Webservice stuff
var startIconUrl = imageDirectory + "startpoint.gif";
var endIconUrl = imageDirectory + "endpoint.gif";
for(i = 0; i < result.length; i++) {
var pointList = [];
for (j = 0; j < result[i].LatitudeList.length; j++) {
var newPoint = new OpenLayers.Geometry.Point(result[i].LongitudeList[j],
result[i].LatitudeList[j]);
pointList.push(newPoint);
if (result[i].RouteIconList[j] != "") {
markerRouteLayer.addMarker(getMyMarker(imageDirectory + "wpicons/" +
result[i].RouteIconList[j], result[i].LatitudeList[j],
result[i].LongitudeList[j]));
//add trail markers
markerRouteLayer.addMarker(getMyMarker(startIconUrl,
result[i].LatitudeList[0], result[i].LongitudeList[0]));
markerRouteLayer.addMarker(getMyMarker(endIconUrl,
result[i].LatitudeList[j-1], result[i].LongitudeList[j-1]));
//add trail line
var lineFeature = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.LineString(pointList),"","");
vectorRouteLayer.addFeatures(lineFeature);
Hope this helps....
Linda Rawson
On 9/6/07, Chris Hardin <chrislhardin at gmail.com> wrote:
> Does anyone know a good way to generate a routing overlay with
> mapserver? I want to send to coordinates to the server and generate a
> route to overlay on the map.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070907/fa70dd9e/attachment.html
