[OpenLayers-Users] Distortion when loading an image layer
Eduardo Patto Kanegae eduardo.kanegae at inflor.com.br
Thu Sep 13 13:23:29 EDT 2007
I´m using OpenLayers 2.4 and because ArcXML is not yet available, I´m
trying to pass dinamic  generated HTTP SRC images to OpenLayers.
The output image appears streched and not how it was originally sized.
 My code:
 szMyImageOutput = 'http://server/output/myimage.png'
 var olMapOptions = {numZoomLevels: 1};
 olMap = new OpenLayers.Map('olMap', olMapOptions);
 var layImg = new OpenLayers.Layer.Image(
                                'The map',
                                szMyImageOutput,
                                new OpenLayers.Bounds(-74.99999968,
 -38.592217934, -31.040414632, 7.99999979),
                                new OpenLayers.Size(1016, 606) );
 olMap.addLayers([layImg]);
 olMap.zoomToExtent(new OpenLayers.Bounds(-74.99999968, -38.592217934,
 -31.040414632, 7.99999979));
But , after loading the layer, the image appears with size of 571w X  606h.
Am I missing any other parameter?
I grab the first code from
 http://www.openlayers.org/dev/examples/image-layer.html
*Links:
http://www.sntgeo.com.br/epk/Output_Wanted.png - the way the image
should appear
http://www.sntgeo.com.br/epk/Output_AfterLayerAdded.png - the way the
image is appearing
 thanks in advance
Eduardo P. Kanegae
