[OpenLayers-Users] Layer on/off
Linda Rawson
linda.rawson at gmail.com
Thu Sep 13 19:05:10 EDT 2007
I don't know if this will help you or not either but here is what I do. I
have a layer that is identified as dm_wms.
map.events.register('moveend', map, function (e) {
myScale = (map.getMaxResolution() / map.getResolution());
if (myScale >= 1024) {
dm_wms.setVisibility(true);
} else {
dm_wms.setVisibility(false);
Linda Rawson
On 9/13/07, bradleyspencer <brad at cubewerx.com.au> wrote:
> Prasad,
> I'm not sure if this will help as I do not use the resolutions that much
> (probably should?).
> Anyway, I set up an event that is triggered every time there is a zoom
> change. Then I can check the new zoom level and if the layer should be
> displayed at that layer I do something like turning it on or off. Of
> course
> it requires me to have arrays of display level thresholds for each layer -
> this I do in an application config file at load time.
> See http://www.ozdemo.org as a working example. Hope this can help you.
> map.events.register('zoomend', null, function(evt)
> var macroCheckBox = document.getElementById('macro');
> zmlevel= map.getZoom();
> // run through the layer controls array setting Checkbox to
> deactive
> for (j=0; j<numLayers; j++)
> var layId= 'layer'+j;
> var layerCheckbox = document.getElementById(layId)
> // if the layer is viewable at this layer set the
> checkbox to reflect
> if (zmlevel < Minzm[j] || zmlevel > Maxzm[j])
> { layerCheckbox.disabled = true;
> layerCheckbox.checked=false;
> layerVisibility(layId);
> else
> { layerCheckbox.disabled = false;
> if (macroCheckBox.checked)
> layerCheckbox.checked= true;
> Event.stop(evt);
> Cheers,
> Brad Spencer
> -----Original Message-----
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]On
> Behalf Of Christopher Schmidt
> Sent: Thursday, 13 September 2007 10:47 PM
> To: Prasad Choudhary
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Layer on/off
> On Thu, Sep 13, 2007 at 04:26:52AM -0700, Prasad Choudhary wrote:
> > Hi again,
> > I tried as you suggest, as
> > which is @ http://prasad.choudhary.googlepages.com/markers.html
> > but still, not happening, is there some thing i missed out? please
> correct
> > me.
> The minResolution of the markers layer is not respecting the value you
> passed in. I can't see why this is at the moment, but it seems to be a
> bug. When I get time, I'll look into it -- for now, something like this
> will work:
> var markers = new OpenLayers.Layer.Markers(
> "Markers",{'minResolution': 0.3515625, 'maxResolution': 1.40625} );
> map.addLayer(markers);
> markers.minResolution = .35;
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070913/8989543d/attachment.html
