[OpenLayers-Users] RC 2.5 may be problem with untiled vs
singletile
Christopher Schmidt
crschmidt at metacarta.com
Tue Sep 18 13:23:46 EDT 2007
On Tue, Sep 18, 2007 at 11:04:13AM -0600, Linda Rawson wrote:
> Okay. I ran the example http://www.openlayers.org/dev/examples/notile.html
> When I look at the rendered source I see for "WMS.Untiled" layer only one
> div with a request for the service:
> <DIV style="LEFT: -99px; OVERFLOW: hidden; WIDTH: 597px; POSITION: absolute;
> TOP: -99px; HEIGHT: 597px"><IMG class=olTileImage id=OpenLayersDiv59
> style="WIDTH: 597px; POSITION: relative; HEIGHT: 597px; alt:
> OpenLayersDiv59" src="
> http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-10.375,23.625,23.375,57.375&WIDTH=597&HEIGHT=597"
> _eventCacheID="OpenLayersDiv59_eventCacheID_60" galleryImg="no"
> viewRequestID="2"></DIV>
You viewed one layer. It requested on image. Good.
> But when I access the other example:
> viewRequestID="2"></DIV></DIV>
> <DIV id=OpenLayers.Layer.WMS_42 style="DISPLAY: block; Z-INDEX: 105; WIDTH:
> 100%; POSITION: absolute; HEIGHT: 100%" _eventCacheID="
> OpenLayers.Layer.WMS_42_eventCacheID_44">
> <DIV style="LEFT: 0px; OVERFLOW: hidden; WIDTH: 398px; POSITION: absolute;
> TOP: 0px; HEIGHT: 398px"><IMG class=olTileImage id=OpenLayersDiv66
> style="WIDTH: 398px; POSITION: relative; HEIGHT: 398px; alt:
> OpenLayersDiv66" src="
> http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-4.75,29.25,17.75,51.75&WIDTH=398&HEIGHT=398"
> _eventCacheID="OpenLayersDiv66_eventCacheID_67" galleryImg="no"
> viewRequestID="4"></DIV></DIV></DIV>
You viewed a second layer. It hid the first layer (display:none -- you
can't see this in the above snippet because you snipped right below the
layer reference). It then created a second layer, and sent a request.
The first layer (contains Div59) is the Layer.Untiled (as you can see from the
Layer Div ID). The second layer (#42) contains one image (#66).
> I see TWO divs with the service request in them. In my case this would slow
> it down because I only want one image on the page for the request.
If you only want one image on the page, don't add two layers.
Regards,
Christopher Schmidt
MetaCarta
