[OpenLayers-Users] Whole Polygon as a Marker. Is it possible ?
Christopher Schmidt crschmidt at metacarta.com
Fri Sep 21 09:13:00 EDT 2007
On Fri, Sep 21, 2007 at 12:00:39PM +0000, Xavier Rayo wrote:
> Hi all!
> continuing with this question, is there any way to select a marker from a text layer with selectFeature hover.
No. You'll need to set up mouse events on each marker, the same way you
register click events. The SelectFeature handler is for vectors only.
Regards,
Christopher Schmidt
MetaCarta
